- 22 Aug 2005
- Clydebank
Since when.. I've seen 3 quoted many places, but I've found that you can often get stuff that's 4 days (mostly) Are you sure it's not 7 for the text servers?
Hmm so less connections but longer retention for a dollar more...
Hmmmm - not sure if its worth the switch really
ps3ud0![]()
news.virginmedia.com is definitely 7 days. I've used it all the time for over a year.
2.5Mb is more than enough, you'll get better speeds than something like Torrent any day.
You may want to go for the 180GB package rather than a monthly sub from Astraweb, although it really depends how much you'll download. You'll have to figure out what works out cheapest for you.
I'm on 512K and Usenet works perfectly for me. Yes, it takes ages to download anything, but that doesn't mean it's pointless, just means I have to wait a bit longer to get the 'latest Linux Distro'.
It's 7 days retention mate![]()
What does the above mean?
Hows Astraweb for that now - I think thats what put me off when I was looking as its completion seemed to yo-yo...The completion is important. If there are bits of data missing here and there, the often-uploaded PAR files can be used to correct for a small amount of data loss, but if your usenet provider only has 50% of what was uploaded in a given day, it'll be frustrating to say the least.
Never had an issue with Astraweb for completion... whether its 1 day old or 600 days old.
They are having some problems at the mo. Reading that quite a few people are getting fed up with them and thinking about going to Giganews.
I run into a completion problem and got a Giga account to finish it off.![]()
Only being able to DL from one IP puts me off Astraweb, otherwise I would switch from Giganews.
Giganews FAQ said:Can I access my Giganews account from multiple computers/IP addresses at the same time using the same account?
Giganews personal accounts are for single member use only. Your account is restricted to a single computer / IP address at any one time.
Giganews don't allow multiple connections from multiple IPs either, in fact none do afaik.
If you are then you are fooling the system somehow :/
If that isn't what you mean and you actually mean being able to take your laptop with you and download on the move, I do that all the time.
