i've got Kinect Adventures, Kinect Sports, Kinectimals, Your Shape and Dance Central.
not really played Adventures as i'm mostly playing Sports when using Kinect.
i do a daily exercise with Your Shape and then onto Sports that is just so much fun when playing against others on-line with the football and Table Tennis being my fav's.
i'm useless at Dance Central but like it, while the wife and daughters have taking to it like a duck to water
Kinectimals is very cute and it keeps the attention of my youngest usually with her only stopping when she's "knackered" as she puts it.
We could have some sort of competition if we get enough peopleDid anyone buy EA Sports Active 2.0 yet?
Has this been updated on the fly? My panels on the Kinect Hub now have a tilt to them when I move my hand over them. Some of the stuff reacts quicker, the selection hand fills up quicker as well, also noticed it on Kinect Adventures. I don't remember getting any updates since the last time I used it.
Does the sensor bar have to be central to the TV, or could it go to the side or at an angle?
At the moment I just whack mine on the top of the telly with a load of Blu-Tack. Works fine, and I take it off when I'm done.
Obviously wouldn't be suitable if you're using a more recent, thinner model of LCD or Plasma.
Blu-Tack sounds like a plan.
Just had it on top of my TV and it balances, though the angle is wrong, so BT to give the back some height and were sorted i reckon.
You can motor the Kinect up and down in the settings it has quite a bit of movement each way...
How do I create multiple Kinect ID's on the same gamertag?
