The thing is cramming a full loop to cool a gtx 480 and a i5 into the Lian Li PC-Q11W. But possibly you could do some cutting and mount a dual rad at the bottom and add single where the 120mm fan is.
No windows on either of those lian-li cases? A V354B could be modded with a kinda side window, allways seems a shame with all the good work that goes into watercooling these tiny cases, and you cant see it 99% of the time
Rich dont do it !!! im only just moving away from my Matx set up after a T07, a change sounds good but the small cases are a nightmare to put any kind of water in, you will be limiting your overclock and i think that would just drive you mad after a bit.
Did the whole SFF thing in a V351B and it did have a certain novelty value, for a while. The heat build up as a result of crap ventilation made it loud and making basic changes became a bore and a chore. SFF cases are a nightmare to work in and limit your choices of hardware. In the end it just become frustrating. Then came the 800D. Bliss.
+1 , did a v351b build aswell, was fun at first...then the problems, heat, kinks, airflow etc. Really do hope you can pull of a SFF watercooled 480 build, its a hellva lot more work than any atx watercooling project imo though.
when i was building, i didnt go h55 plainly due to cpu socket layout (but water would solve this), pushing a 32nm CPU to a 4ghz oc wont stress the mobo as much as an i7 would, which is where the boards cant cope with the heat.
That why dfi released a bios locking down the overclocking capabilties for i7's, people could get 4ghz + easily, its just a case of when(not if) the board will melt.
