Black Ops latency trouble
14 Oct 2008
Hey all!
Bought black ops last thursday, and LAN'd round a friends house until yesterday evening with no torubles at all, upon trying to play back at home the latency fluctuates HUGELY, one second it's 50, then it's 500, up/down/up/down constantly (even in the server browser page when refreshing my favourites)
ALL other games work 100% fine with a ping of 40, download speeds are fine, and no-one other than me is using the connection, i don't torrent nor do i stream anything (other than youtube!) so there is no concievable possibility there is a problem with the connection.
This leads me to beleive it is something with the combination of black ops + my router, anyone got any ideas?
I'm not a technical whizz when it comes to routing/net type stuff, also google is failing me :(
ANY help much appreciated, I must hit prestige! :p
Make sure you have downloaded all the patches and updated your graphics card's drivers, and if you are still having problems, try turning off shadows and reducing texture quality.
Done the usual commands?
cl_maxpackets 100
snaps 30
Also, http://portforward.com/ just to cancel that one out.
ISP and router?
Hey,
Yeah tried those 2 commands to no avail unfortunately, will have to try portforward when I'm home from the office.
ISP Orange, router is netgear I think, will update when i get home.
Thanks for your swoft responses guys, appreciated :)
Tom
After 2 hour last night seemed to stumble across a lucky combination of events,
THE SOLUTION (all be it, a very odd one at that), not being a networking wizard I cannot explain the anomaly, this may be beneficial to someone else should they have the same problem;
- open ports 3074 are opened for both TCP/UDP (not neccessary to begin with but see below)
- Attempt to login, hangs at 'connecting/fetching stats' screen, Cancelled this by pressing escape
- Close the ports again
- Login to Blackops fine, see the fluctuating ping as expected
- ALT + TAB, re open port 3074 on TCP/UDP again and apply
- Voila - 50~ steady ping on my poop 1mb connection (live at the tail end of 2 exchanges, all we have is copper wire :( )
Not practical at all, nor can I explain it, but for some reason it seems to work, we're going to try another router at my place today, having to do that each time is a nightmare!
