- 12 May 2010
- West Bromwich
Well, as I promised earlier in the week, I 'm posting my findings after fitting one of these Zalman aftermarket coolers to a POV GTX 470.
Tips when fitting
- Borrow or buy a set of precision screwdrivers before removing the stock cooler from the PCB. Test each head, and use the one with zero 'play' in it when you turn it. I borrowed a set from a sparky at work. As for the exact size that worked for the card, well it said PH1 x 65 on it, which I'm assuming in screwdriver language is phillips head 1. This fitted perfectly.
- Before removing any screws, run furmark for 10 mins to warm up the threadlock. I did this on someone elses recommendation, don't know if it made any difference but I didn't have one single problem with screws that wouldn't turn. Remember to push down with some force slightly when turning.
- Unless you have severely under-developed baby fingers, you'll need some tweezers to put the rubber washers on the back of the black video memory heat sink.
- All washers bar the clear pvc ones have adhesive backing, which helps enormously when assembling the cooler. The clear pvc ones don't need adhesive anyway.
- You'll need a small ice lolly shaped piece of plastic to put the Zalman thermal paste on the video ram. It's very goopy, and doesn't apply very well. Looking back on the installation I wish I would have tried some of the MX3 people talk about on here. It is nigh on impossible not to spill some on the PCB when applying it to the ram, but it's none conductive so isn't a big deal.
- Once you've put the thermal paste on the RAM and GPU, fitting the rest of the cooler to the card is an absolute doddle. Just a case of turning it upside down and turning 4 screws much like you would fasten down a heatsink on a cpu.
Performance
At stock clocks my 470 used to sit at 45-55 when idle. With the Zalman, it idles at 25. The best part about it though is the noise when loaded. I can run an overclock of 850 now, thanks to the help of some lads on here, and even with the fan mate controller on minimum, the card doesn't go above 50C. The previous POV stock cooler would have been up in the 90's with these settings.
Overall I'm impressed with the cooler, in particular no longer having to listen to a jet engine 4ft away when I have a game on. Good stuff
Tips when fitting
Performance
