FAO male users
Apparently your index finger is longer than your ring finger if you were exposed to high levels of testosterone in the womb, so they are hypothesising it's something to do with that. Mine is shorter btw :(
Wrong way around, if you have longer index finger then you were exposed to less testosterone.
I wonder how this works with women, as there are some meaty women out there! Wonder if they have shorter index fingers and were exposed to higher levels of test!
My ring is bigger than my index finger. What does that mean?
It means you're a big manly man oozing with testosterone but will probably die of prostate cancer*
*may be a slight exaggeration/lie
Wrong way around, it means he's a limp-wristed sack of oestrogen stressing over not being pregnant yet, suffering from menstrual cramps and prone to bursting into tears at a slight drop in room temperature :p*
My Ring Finger is definitely marginally *longer than my Index Finger. At least I don't drink or smoke and I do go to the gym...so with a bit of luck that will help!
