thermaltake III
remove all the logos etc or if they wont come off then detatch and respray the front matt black and perhaps the red bit at the front also. remove the roof vent and replace with something a bit less subaru
maybe replace window with a black tint type.
have fun and remember you actually can make a silk purse out of a pigs ear
Had the blue version of this years ago, i think its still in the loft. Great case in its day but them 80mm fans were so loud :).
I had the blue one as well. It has found a home with my brother in law. Messy wiring with all those cables going to the controller but a good case for its day.
Zairs its a case...and its not another T07 or 800D, i for one am interested in PC builds my friend, so go and make the best PC you can out of it, if you dont want to mod it will be a lil bit noisy as 80mm fans tend to make a whiny noise at full revs, if you want to mod the case we will give you any help we can, **** the haters, it takes skill to make a good setup out of a "bad" case, its easy street if you use one of the new ones (8000d) and being your first build the main thing is to get it all in and working.
Some of the people posting on here should remember there first build and give some support FFS
EDIT and dont make 2 threads about the same thing...it ****es people off (including me :))
