Caporegime
- 28 Jun 2007
- Tamworth, UK
They control mavity and The Sun respectively.
OP missed out on potential man points - just switch it off and see what happens/didn't happen/didn't work/broke.
Buttons are there for a reason - to be pressed.
in reality, all I do is press buttons and mess around till something works![]()
Can you turn The Sun one back on please, it's getting a bit cold.
See if you can overclock them....![]()
You should bump up the volts your immersions. You're on water so pushing +20 to 30V should be easyI can make the numbers get bigger, does that count?![]()
Once activated you have to push the buttons every 108 minutes, or there'll be a build up of magnetic energy which could potentially destroy the world.
