In fact...
Could a mod or the OP stick this in the first post please?
Cheers
Disclaimer - All information lifted from the Modaco ZTE Subforum, kudos and thanks to the original contributors in the linked threads. All I've done is collate their findings, insights and useful information in this post. Everything links to Modaco threads as files are updated often, so deep linking is pointless.
:: Orange San Francisco Android Smartphone ::
First stop for anyone wanting to know more beyond the below is the Modaco ZTE Blade subforum.
Spec
- Android 2.1 Eclair
- Qualcomm MSM7227 600MHz processor
- 512MB RAM
- UMTS 900/2100 MHz
- GSM 900/1800/1900 MHz
- HSDPA (3G+)
- 3.2 megapixel camera with autofocus
- 3.5" WVGA (800x480) OLED capacative touchscreen
- WiFi 802.11 b/g
- Bluetooth
- FM radio
- GPS
- Accelerometer
- Digital compass
- Light sensor
- Proximity sensor
- 116mm / 56.5 mm / 11.8mm
- 130g
- 4 hours talktime (lol - agreed!)
- 9 days standby (lol - agreed!)
Full review here.
Unlocking
Everything you need in the link below, didn't want to cross link on this site as I'm not sure if it breaks the rules or not.
Full details found here.
Process:
- Use the dialler and enter this to see your IMEI: *#06# (don't press Call!).
- Get your unlock code from the site above.
- Double-check you used the correct IMEI number -- it's free to retry!
- Turn off your phone.
- Open the back.
- Remove the battery.
- Remove the (Orange?) SIM card.
- Insert a SIM card from a different operator.
- Replace battery.
- Replace back.
- Turn on phone.
- (If prompted, enter any PIN number that you may have set on the new SIM.)
- Now you should be prompted to enter the unlock code. Do it carefully!
Superboot/root
Rooting is the process to gain full control over the phone, and allows you to install applications that require root access and those not signed or approved by Google. This is similar to the iPhone jailbreak in a way. Other things you can do once rooted include Apps2SD, tethering, backups, custom ROMS... blah blah.
More information
here explaining why you should root, and
here.
How to full details here.
- Download r3 Superboot for ZTE Blade - DOWNLOAD (ROMraid Load Balancing) - MD5: 03105bbbf5120535c8921075822a1b67
- Download fastboot if you do not have it already.
- Turn off your phone and take out the battery. Unplug the phone from the PC / charger.
- Replace the battery and turn the phone back on with 'volume up' held. The device will stay at the 'green android' screen.
- Plug the phone into the PC.
- Extract the fastboot zip file.
- From a command prompt (at the directory containing these new files!) run 'fastboot-windows flash boot boot.blade.superboot.mcri.r3.img' (subsituting 'fastboot-mac' or 'sudo fastboot-linux' as required)
- When this finishes, from the command prompt run 'fastboot-windows reboot' (again substituting 'fastboot-mac' or 'sudo fastboot-linux' as required)
- Done!
Clockwork Mod Howto
Clockwork Mod is a means to backup and restore your phone to/from SD. It's also a very good mechanism for apply ROMs, updates and patches. It is heavily used in deployment of custom ROMs on Modaco.
Full details and guide here.
Custom ROMS and Installation
Master thread of custom ROMS and Guides - Great thread!
Direct links to ROM threads, highly recommend reading the above thread through as it links to them all. The choice of what you go for is entirely up to you, so people have more luck with some ROMs than others. The Modaco ROMs seem to be most popular, but development appears to have slowed a little (until the 2.2 release yesterday 01/12/10).
Direct links to ROM threads.
2.2
Modaco 2.2 Alpha r2 (warning, alpha!)
FLB's 2.2 Beta
Frankish 2.2
2.1
r4 Modaco 2.1 ROM
BladeVillain ROM
Hungarian Hedgehog 2.1 ROM
Stock ROMS
Other Stuff
USB Drivers
Cases + Screen Protectors
HTC IME Keyboard Repack
