Just do this, problem solved:
What if your face freezes?
Then you'll be stuck with a silly facial expression for the rest of your life!What if your face freezes?
I just run my car for 5 minutes before I leave with the blowers on max. Usually everything will melt quite quickly and I can just use the windscreen wipers to get it off. Unfortunately, despite having a Ford, my car missed the heated windscreen by a few months![]()
What car do you have? Heated windscreens have been around in Fords for many many years, its likely it missed out because of spec, not age.
I had to use my B&Q discount card to scrape the ice off my windscreen! Didn't work though, only got 10% off.
Well there are Escorts with heated screens afaik, so I doubt it is because of age, but rather because LX is base spec. Even on the MK2 Focus the LX didn't have a heated windscreen as standard.
Either:
406: Wake up, run outside fire up car with blowers on max, shower, get ready, drive to work
Bugger this de-icing malarky!
Unless you can be bothered to carefully poor the water over your car so that it doesnt touch the path, you'll just turn your driveway into an ice rink.
