Best Monitor for xbox 360 Gaming Only
8 Dec 2010
Hi peeps i kno there has been a few topic with a similar theme.
All it is i like to think i take my gaming quiet serious and atm i use a LG W2261vp which is ok for the moment but im looking to spend approx £200 + on a 24 inch monitor. HDMI is must aswell
Firstly is that the best size to go for? or is 26 + inch worth it bearing in mind it only xbox it will be used for. Picture Quality is a MUST !
Ive had my eyes on the following :
IIyama E2472hd - http://www.overclockers.co.uk/showproduct.php?prodid=MO-060-IY&groupid=17&catid=510&subcat=
M227WDP.
Samsung BX2450
but then i also like these.
Samsung P2450H - http://www.overclockers.co.uk/showproduct.php?prodid=MO-124-SA&groupid=17&catid=510&subcat=
BenQ Ew2420 - http://www.overclockers.co.uk/showproduct.php?prodid=MO-044-BQ&groupid=17&catid=510&subcat=
Internal sound is prefered but i do know some cheap 2.1 is probably prefered by most. But i use Steelseries 5xb majority of times so a monitor with a jack is a MUST
If anybody can put me in the right direction i would apprechiate it ;)
It's a tricky question. How do you find your current monitor? It's one of the better ones available going by my experiences with the 23 inch version. Obviously you want something bigger but if you would like a 'similar' level of colour vibrancy, for example, this would change my recommendation. Maybe you want something a little different.
I would go for the samsung P2450H you have linked there. It is a quick monitor, decent image quality and has HDMI audio pass-though, so you can link in headphones or some decent speakers (this set are a good value choice) to the monitor itself.
out of stoke andi! i was thinking about about picking up a pair of these myself after seeing you recommend them before. i think you've been linking them too much! :)
If your happy with the image quality then this would be my recommendation too. It will offer a fairly similar but 'larger' experience.
I watched a video of the Samsung BX2450 and the kid was playing halo reach look amazing tbf im just unsure before i had the LG i had syncmaster 2333hd which i couldn't get on with i do want a bigger screen bt want the amazing colour and quality with it.
If you saw an image on your LG that looked 'amazing' it was your current monitor you were pleased with. The mind is a powerful tool ;). I would suggest the Samsung P2450H. The reason I say this is that the colours on the BX2450 are lovely and varied but a little muted compared to the P2450H. This may not be a welcome change for you or you may love it. It depends on your point of view.
Yeh i know what you meen is there any others on the market you recommend?
I kno it a bit sad bt on Bx2450 i love the back i kno i will never see it bt does look smart and doesn't it have x2 hdmi?
M227WDP.
Samsung BX2450
Go buy an Actual TV made to do this...
