Cam someone post a link to some £250 570s?Doesnt quite beat 570gtx which is £250
All be on website after midnight. Any order you place before 5pm tomorrow will go out that same day on next day courier for sure as long as its in stock, hence HIS is the safe bet as in stock now.
The new drivers are much faster, but I did not get them in time. The new drivers basically mean a 6970 beats a GTX 580 in tessellation or at least is no longer chasing it.
Wait for reviews tomorrow guys, its a fantastic card for the money, but the GTX 580 does still have outright power, but it cost more.
For the same money I'd be bagging myself a pair of 6950's.![]()
I wouldn't say suck, they are the only thing that makes Black Ops playable for me, they also seem to bias on quality over performance in quite a few things - probably due to being Quadro drivers I do see an increase in IQ in some stuff.
My Heaven 2.1 scores are a bit mixed tho, they give better min fps on the first run and good extreme tessellation performance compared to other drivers I've tried but don't seem so hot at normal tessellation.
Lower resolution, and no details about whether the card was run at stock or overclocked.If this is true, they don't look like a fail to me.
and get banned for it? They are available, and if you look hard enough you can fine 580's very cheap as well.Cam someone post a link to some £250 570s?
Huh, have you been looking at the benchmarks? I haven't seen any leaked benchmarks show that the 6970 is slower than GTX 480 which is equal to GTX 570 in performance. Why do people keep thinking GTX 570 is way faster than 480, it isn't. About 80% benchmarks seem to suggest that it performs a little slower the GTX 580. The other 20% seem to suggest that it might outperform GTX 580 with new drivers. And this is just for tessellation since we've been only seeing a bunch of Unigine benchmarks.As I have said before 6970 is a bit fail at £279 quid.
Doesnt quite beat 570gtx which is £250 and it doesnt come close to 580.
Wait for the reviews, as I did not test a 570. From what I've seen they will be close, though 6970 does seem to have better clocking potential.
Wise guy huhand get banned for it? They are available, and if you look hard enough you can fine 580's very cheap as well.
True, but he says this though:
http://forums.overclockers.co.uk/showpost.php?p=17999231&postcount=385
and lots of new little nooblets hanging around
Win all around.
What are the highest overclocks seen from the 6900's so far? Both GTX570 and 580 offer about 20% headroom.
I wouldn't be that harsh m8. You're irritating but I wouldn't call you a nooblet![]()
