OCP are AMD biased.
Funny that you mention it, you used to quote [H]ard|OCP reviews every time you wanted to prove that Nvidia beats ATI to death
If you've read that review, you'd realise that HD6970 is faster at 2560x1600 in any game even though it uses 8xAA compared to 4xAA with GTX570. Apples-to-apples comparison and HD6970 is 15% faster than GTX570. More memory helps a lot I think.
They only pay $20 extra for the HD6970 over GTX570 in the US.
nopeAnyone's fan speed up very fast several times on bootup? my vapor-x didn't use to do this lol and also the fan seems a tad noisy.
Oh well time to test.
nope
maybe u need a bios update....Any idea what it could be? card working fine though just tried WoW maxed with ultra shadows and 8xmsaa getting 60fps nearly all the time.(on my 5870 i could go these settings but it would get stutter sometimes like the memory was being pushed to it's limits so had to lower shadows and msaa to x4.)
Should i be worried about the fan thing? card works fine so guess it be ok.....max temp on 50% fanspeed i seen so far is 70c which isn't too bad i guess.
Going to try Heaven now.
the driver i used were the 10.12 display drivers only package first then installed the ccc2 preview package.
Could please check what are your 2D(idle) frequencies once everything's installed? I'm curious to know if it is just me having an issue or if it is indeed a Catalyst related bug and therefore it will affect everyone.
Cheers
Neither, just one standard 24' monitor
Just noticed something strange, with the drivers uninstalled GPU-Z does report the 2D frequencies to be correct (250/150).
I don't get it, no drivers=right frequencies and with drivers=wrong frequencies. What the hell is going on
