thats vga socket.
Malazan, did your graphics card not come with a DVI to VGA adapter? They usually include one in the box, i.e. this:
Then all you need is a VGA cable (male both ends). You might have one lying around, I somehow have tonnes of them.
Do you only have the TV connected to your PC or have you got a monitor and TV connected at the same time?Hmmm, all i'm geting is the desktop background i've tried a vid off the Hard Disk - nothing.
Is the only thing you see the desktop background or can you see the taskbar/Start menu, windows etc?
What happens exactly when you play a video? Do you see the media player software with a black area where the video should be or just absolutely nothing appears at all?
Hi there,
May I ask what version of windows you are using?
Also, how did you set up dual screen? Did you use the "Nvidia control panel" and select the "dualview" option?
