Maybe cycling would be a bit difficult, but cycling in the snow isn't actually that bad... just today I've seen several people cycling through the snow, and one of them noted it was slower than usual, but otherwise fine.The snow is really bad around here, plus windy
1: So cycling is a big no no!
Taxis charging double time round here.
If you genuinely can't make it into work because of the weather you should contact your employer as early as possible to let them know. Your employer cannot force you to attempt the journey and in fact many good employers are sympathetic to conditions outside of your control. Unfortunately if you cannot get into work your employer is under no obligation to pay you.
At the end of the day, you are paid to be there doing the work. It's not your manager's problem if you can't make it in. It's down to you to get there, even if it is difficult or expensive. It would be nice if your manager cut you some slack, but they're not really obliged to so far as I'm aware.
Same here. I got to work, when someone rang in unable to make it because of the snow, I offered to go and collect them, when my manager offered this solution over the phone the person responded that this would be illegal and I had no right to come and pick anyone up.
People just like to skive.
Hey, I just thought I'd pipe in, in sub zero conditions if you're active (walking or whatever) it's essential to take layers off to keep cool, sweating makes your clothing damp which then freezes which isn't goodThe other day on the radio a guy called up and said he ended up taking a walk in the snow to get home. After a few hours he was kind of stranded and then ended up waking up in hospital the next day and was so close to dying from hyperthermia. If you do walk, take a torch, water, and keep warm and don't take layers off if you feel warm.
Jesus christ. A bit of snow and loads of people think they shouldn't have to go to work. Put some wellies, a decent coat, gloves, hat and scarf on and get to work you workshy pansies.
You're so cool.Jesus christ. A bit of snow and loads of people think they shouldn't have to go to work. Put some wellies, a decent coat, gloves, hat and scarf on and get to work you workshy pansies.
Never have. Have walked 10 miles though. But those in Russia, Canada, Iceland, Norway, Denmark, Sweden, hell even Scotland have done so for centuries.
