22 Dec 2010 at 19:43 #1 helpimcrap helpimcrap Soldato Joined 13 Jan 2004 Posts 12,791 Location Leicestershire Download speed 3286 Kbps Upload speed 411 Kbps
22 Dec 2010 at 19:59 #2 #Chri5# #Chri5# Soldato Joined 27 Feb 2003 Posts 7,376 Location Shropshire Good compared to what?
22 Dec 2010 at 20:00 #3 rpstewart rpstewart Man of Honour Joined 11 Mar 2003 Posts 10,706 Location Greenock, Scotland A little context would help, without it the best I can say is "maybe". Is that a speed test or the router stats? What ISP? What are your line stats?
22 Dec 2010 at 20:02 #4 LiamJ LiamJ Associate Joined 19 Dec 2010 Posts 1,394 It certainly could be better. Most upload speeds in the UK don't get much faster than that due to the cables.
22 Dec 2010 at 20:17 #5 hyperst hyperst Soldato Joined 16 Dec 2008 Posts 4,086 Location Lincolnshire LiamJ said: It certainly could be better. Most upload speeds in the UK don't get much faster than that due to the cables. Click to expand... uplaod speeds are reduced for a reason, it's not the cables
22 Dec 2010 at 20:22 #6 Walsandrew Walsandrew Associate Joined 23 Oct 2010 Posts 339 Location Compton, CA helpimcrap said: Download speed 3286 Kbps Upload speed 411 Kbps Click to expand... if you live in the uk, yes. if you live in korea, which i don't think you do, then no.
22 Dec 2010 at 20:48 #7 gazzaa gazzaa Associate Joined 6 Jan 2004 Posts 1,191 Location leicester theres mine normally a bit faster but there you go.
22 Dec 2010 at 21:13 #8 helpimcrap helpimcrap Soldato OP Joined 13 Jan 2004 Posts 12,791 Location Leicestershire sorry... phone connection on sky bb.
22 Dec 2010 at 21:19 #9 shroomz shroomz Associate Joined 18 Feb 2010 Posts 2,254 Location Glasgow, UK Are you using their supplied Netgear DG834GT router? If so, download routerstats, run it, tell us your signal to noise ratios (SNR), and your line attenuation I'm getting 15Mb down, 2.5 up with 33.9db attenuation down and SNR of 3.5db to compare, but I'm with Be* and use another router(Thomson 587). Last edited: 22 Dec 2010
23 Dec 2010 at 14:43 #10 gazzaa gazzaa Associate Joined 6 Jan 2004 Posts 1,191 Location leicester just got my 50 meg connected
