The update appears to have also added a little green blobby thing to text fields to make it easier to move the carat, and I have a sneaky feeling it has affected my battery life.
In a bad way, have yet to see really... I did however have a dream last night that my battery has discharged from 100% to 1% in a few seconds and then melted! lolIn a good way or a bad way for you? I'm not sure if I'm imagining it but my battery life seems to have improved dramatically since updating.
Those green selection blobby things have always been there.
Which speed test did you use? The speedtest.net app has never given me a true speed on T-Mobile.I also ran speed test and I'm only downloading at 26kbps on 3G? I'm on t-mobile.
That one. It is seriously slow and WiFi connects to detect the true speed. What were you receiving ? Alternative apps?Which speed test did you use? The speedtest.net app has never given me a true speed on T-Mobile.
FYI temp root with VISIONary doesn't work after the update.
Mine was always showing as like 16k I can't remember what other app I used, haven't done a test for a while.That one. It is seriously slow and WiFi connects to detect the true speed. What were you receiving ? Alternative apps?
Great... Just installed the OTA update, and was going to root today, didn't read to see I wouldn't be able to after... Is there a way to downgrade or root another way yet? (Or will it be possible later?)
