How does this work if 6970 reqs 6 & 8 pin but 6950 is using 2 x 6
Easy.... Have temps changed ?
Methinks some power circuitry somewhere is going to get a little warm this winter!![]()
Thought 8 pin just provided extra earths and not additional volts?
Just don't boost powertune up. The default power setting is around 200 watt, the 2x6 pins and PCI-E slot is more than enough for that.
@ Easyrider, have you noticed any changes in heat output from your "new" 6970 at all. I'm just wondering if its pulling more amps due to the increased shaders.
Before
After
How come I get 1600 shaders?![]()
Me too - my 6970 is still with OCUK, I'm wondering whether to call and ask for them to change it to the 6950 . Oh what to do......Must resist RMA....
Is this an educated guess, or are you sure?Just don't boost powertune up. The default power setting is around 200 watt, the 2x6 pins and PCI-E slot is more than enough for that.
Why would one card require extra earths, but not the other? It would be a bit daft for them to have to make the two cards different if there was no need.Thought 8 pin just provided extra earths and not additional volts?
Easyrider - nice job, well done.
So you think you have a 6970 now - but it's barely different to your OC'd 6950, so the question is, can you overclock your 6950?
oh bloody **** i guess it saves me from flashing we should have knew this earlier !!! damn
I'm in the same boat.
Bit p1**ed off with AMD really. There is now no difference between the two cards apart from the price? Great work AMD....
I wonder if OcUK will keep the 5% discount I got for ordering the other day and apply it to a 6950 - I spent the extra £60 as a treat to myself and get slapped in the face with this the next day.....![]()
