Paint job
28 Oct 2010
Colchester
Hi,
I have the lancool k-62 case, I want to spray/paint the inside all White but I don't have a clue how to do it!. What I need from you guys is:
What stuff do I need for the job?.
How many coats will it need?.
Thank you
Your better getting it powder-coated. Its where your case would be electrically charged and negative charged powder would be dusted over it. Once its totally and evenly covered its baked in an oven which turns it from a powder to a very durable paint. This wont chip or scratch anywhere near as easy as if its wet painted like you would do yourself. Set up your trust and will send you some info on powdercoating.
To give you an idea of durability, powder coating is what they do to car wheels when they get painted - and they can take plenty of abuse :)
Definately +1 for that over spraying :)
