That was my first thought aswell.am i missing something?
CAN see it on bios
CANT see it on windows
sounds like a simple 'forgot to partition issue'?
CAN see it on bios
CAN see it on bios
does windows installer see the hdd on sata2 port?
the first one you mentioned is the ahci driver...you would need to have ahci set in the bios first to use this...i would only use it if it were a ssd you were installing on to....
windows should see a sata3 capable hdd thats plugged into the sata2 port (there backwards compatible) once windows installs..... install the chipset drivers from the mobo cd and every other relavent driver you need including the sata3 driver(which will be on the mobo driver cd)do a restart so windows can see all the new drivers then shut down,pull the power and change the hdd from sata2 to sata3...the hdd will now run windows on sata3
it cant see it to install windows on
you cant choose to partition a drive if it doesnt show up
so the windows installer can't see your hdd, your not actually 'in windows' yet?
they have sata3 nowi gotta keep up
Yep haha.
I'm off to football anyway, will try again tonight.
sounds like you may have a duff drive craig![]()
do you have another pc you could try it on?
what game are you going to see? im a hearts supporter myself
were chasing celtic for 2nd spot just now![]()
