*** The Official Heaven Benchmark Thread ***
Caporegime
24 Dec 2005
Autonomy
Please post a screenie and your card and clocks. If you can't be bothered to post a screenie then don't post.:)
AMD Radeon 6950 Flashed to 6970 @ 920/1420
4870 standard
6850 stndard
6950 standard
6950 oc 840 / 1300
Not sure whats causing my min fps, Seems to be the same as the 6850.
Possibley the 620 holding me back.
This is my best run so far, but recently my Heaven Benchmark has been crashing, saying some error. If I can catch the error I will post it up
increased my cpu to 3.7 and gfx still at 875/1225 , not a bad increase for only 100mhz bump lol (0.6 increase pointless tbh )
. time to replace my phenom II with the intel i7 me thinks
For those of you wondering why you get way worse min fps than some on here with the same specs it is because they are letting the bench run through once before starting so all textures are cached etc.
Here's mine, not bad for a 15 month old card :)
You seem to have a very high minimum and running at 1920 * 1200 instead of 1920 * 1080 :-) (You could get higher score with the lower res). What is your CPU clocked at?
Easy: Soz I can't play yet.. my PSU blew up :-(
You can up your minimum fps by a lot if you run heaven for a loop or two before benching.
Sometimes it's just luck that it doesn't drop below 40~ for even a split second
