Budget Gaming Spec
28 Dec 2003
Aberwristwatch
I already have a ATI 5770 bought from these forums and a 450w psu.
Was thinking of building a spec similar to the Titan Nero
http://www.overclockers.co.uk/showproduct.php?prodid=FS-259-OK
Am reusing hd, dvd and screen from my old system.
So the spec will be:
Case: Xigmatek Asgard - Black £28.99
CPU: AMD Athlon II X2 Dual Core 250 3.00GHz (Socket AM3) £42.99
Motherboard: Gigabyte GA-880GM-UD2H 880G (Socket AM3) DDR3 Motherboard £69.98
RAM: OCZ Gold Low Voltage 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Dual Channel £37.59
Any better suggestions or something I've overlooked
get this RAM
If your budgets that tight youd be better getting one of the lower spec previous gen mobo's (760G) which would save you £20 which you could use to up the CPU, if you can go for a quad, like the 630 if its too much you can squeeze in the X3
E.G.
AMD Athlon II X4 Quad Core 630 2.80GHz (Socket AM3) - Retail £75.19
Asus M4A78LT-M 760G (Socket AM3) DDR3 Motherboard £48.99
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX4GX3M2A1600C9) £39.99
Xigmatek Asgard Midi Tower Case - Black £28.99
Total : £233.13
Thanks. Just to check, is your total correct there?
Your basketProduct Name Qty Price Line Total
(£63.99) £75.19
(£63.99)
(£41.69) £48.99
(£41.69)
(£34.03) £39.99
(£34.03)
(£24.67) £28.99
(£24.67)
Sub Total : £164.38
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £11.25
VAT is being charged at 17.50% VAT : £30.74
Total : £206.37
Not particularly fussed about the case as it will be under the table and out of sight. As long as I don't slice my finger open, I'm sure I'll be happy with it. Would rather spend it on 22-24'' monitor
