- 12 Jun 2005
- A lake!
Nice, hope you get one that doesn't crack and everything lines up properly.
Nice one Scott, what colour? Surely not yellow?!
If they don't have it in the first batch then i'll take any other colour as long as it's tangerine.
I ordered the Works raw. It will match my wheels.. If they don't have it in the first batch then i'll take any other colour as long as it's black.
Sweet, the Intense Works finish is badass![]()
Fine? Are you starting new years celebrations early? Apart from the fact that the "sealed" bearing cover fell off, it's full of mud and doesn't turn, yeah it's....fine.
Edit...in other news...
Just put down a deposit on one of these:
Ahem.
"Thanks supercow"
"Ah no worries littlescott, getting you a discount was a pleasure"
Currently sits at 22.5lb/10.2kg, but there's still changes to be made, new XTR pedals are in the xmas post somewhere, cut the steerer, work on the fit, possible change in bars and to a layback post. It's also likely to gain front suspension after the winter.
I did the 50km Winter Challenge today crossing Salisbury Plains.
My overall was time 2hrs 36 mins plus 17 minutes stationary fixing a puncture - grrrr
Details here - http://connect.garmin.com/activity/61607599
It's a very well organised event and a great start to the new year![]()
Yeah me too. I suspect the Ardent front tyre is adding 1lb to the overall weight.Very Nice, Although I'd have expected it to be less than 20lbs
