Man of Honour
- 29 Mar 2003
- Stoke on Trent
Suggestions wanted for the best calendars please.
Robbie, thanks for this. Adblocker wasn't working for me, but this works a treat.![]()
is there any good sports/walking trackers that have offline map tracking out there? i had runsat and gpsb sports tracker on my winmobile which were quite good as you could load the map up at home via your wifi but i cant find anything like that for android. is there any free satnav/route guidance that doesnt have to use your network too, been on payg means you can soon clock up some tariff useage if your not carefull
any decent wifi apps out there that doesnt use much memory and battery power, bit of a pain at the moment as i have to go into settings all the time to scan for wifi signals
[SKR]Phoenix;18122781 said:I use the WiFinder app. Most of the time, I can just enable wifi to connect at work and home, but when I am out and about, I need something to do a quick scan, WiFinder works great!
Not used it, but I saw Runkeeper mentioned somewhere. It's free for January.Viewranger GPS is fantastic.
Admittedly you have to pay for the Ordnance Survey maps to make it any use as the free supplied UK map is very low detail. For instance it cost me about £25 for all of Dartmoor (1:25000 Explorer tiles) which is as high detail as you can get.
It works fine in when you have no mobile phone connection as all map data is stored on the sd card and tracks walks / routes you take recording start / end times, distance, elevation, average speed and other info. Its not aimed as a fitness app so wont caculate calories burned etc but as someone who enjoys walking in the country I cant rate it highly enough.
gonna download [runkeeper] just cos it's free lol - don't even know what it is yet hehehehehe
I'm looking at phone security and recovery if it get's lost. I know there's not much you can do if the phone is stolen and the sim card removed but i've tried the norton security app. This allows me to lock, locate (gives gps coordinates) and wipe the phone. Are there any other apps, perhaps better featured than norton that are worth considering?
I wasn't aware you could do anything if someone changed the sim, especially track the thing!! I've installed Prey and set up an account and I'll do the same with ES Security Manager. Hopefully I'll never have to use the apps but it would be a great excuse to play detective!!
