Cannot update PSP
17 Dec 2004
Ive been trying to update my sisters psp that she bought of ebay cos it wont allow her to play "disney pixar up"
The software ver currently on psp is 3.52 M33
Ive tried the latest version and a older version and it just restarts and says "psp game could not be started (dadadada)"
Any ideas why it wont update guys?
Right you could try this,
Try entering the custom firmware menu by turning off the PSP completely by holding down the power button, then hold down the R button when you turn it back on, There should be a setting in the menu somewhere that makes it so the "Network Update" option searches for M33 firmware instead of the official firmware, try disabling that and then try updating via wi-fi again.
If that doesn't work then try using this method here http://us.playstation.com/support/systemupdates/psp/pc/index.htm
Might depend on model but it's definately the R shoulder button on my PSP. I'd echo comments about leaving the CFW though. Look at updating that instead.
Won't a new PSP game have a legit FW update on it, can't he use that?
It won't work as CFW blocks all OFW updates from running
That won't work either since as I have already mentioned all OFW updates are blocked from running with CFW installed so the only way to do it is to use the same methods for putting CFW on to put the OFW back on.
