- 20 Jul 2009
- Midlands
Today Overclockers UK are proud to present the ultimate in Gaming Headset Technology. The QPAD QH-1339 is the most feature packed headset on the market. Designed from the ground up and based on an jet fighter pilots in flight headset the QH-1339 is packed to the limits with todays modern advances in noise cancellation and audio reproduction. Where every sound is vital in your survival, the QH-1339 delivers with pristine accuracy ensuring you are the top of your game. Dont just play, WIN! Get yours now!
QPAD QH-1339 USB and 3.5mm Mini-Jack Premium Headset @ £259.99 inc VAT
The QH-1339 is ideal for all gaming, multimedia and voice over IP applications as well as for use with mp3 or Hi-Fi systems. The technology of the QH-1339 is based on an aviation headset, perfected for the difficult conditions of noisy cockpits and now adapted to the special demands of lan parties and long gaming sessions. The closed design guarantees absolute undisturbed enjoyment of game and sound combined with a high comfort due to soft replaceable ear and headband pads. The QH-1339 exceeds all expectations in terms of performance, sound and comfort.
QH-1339 Features
- 5-year warranty
- Closed headphone. Reduces surrounding sounds with approx.18 dBa
- Superb studio quality with brilliant highs and very deep bass (5 - 30.000Hz)
- Noise-cancelling c microphone for crystal clear communication.
- Rugged steel headband with soft replaceable ear and headband pads.
- USB sound card with volume control and microphone mute function.
- Modell: QPAD®|QH-1339 Premium Gaming Headset
- Other: Including USB soundcard
- Art.Nr. 3300
- EAN: 7350020290640
QH-1339 Technical Specifications
Headphone
- Transducer type: Dynamic
- Operating principle:Closed
- Frequency response: 5 - 30,000 Hz
- Nominal impedance: 32 ? per system
- Nominal SPL: 96 dB
- T.H.D: < 0.2%
- Power handling capacity:100 mW
- Sound coupling to the ear: Circumaural
- Ambient noise attenuation: approx. 18 dBA
- Headband pressure: 3.5 N
- Weight with microphone and cable: 380 g
- Cable length and type: 2.5 m, straight cable
- Connection: Mini stereo jack plug (3.5 mm)
Microphone
- Transducer type: Condenser (back electret)
- Operating principle: Pressure gradient
- Polar Pattern: Cardioid
- Power supply: AB powering
- Supply voltage: 1.5 - 9 V
- Current consumption: <0.5 mA
- Nominal impedance: approx. 1.5 k?
- Open circuit voltage at f = 1 kHz: 20 mV / Pa
- Frequency response: 30 - 18,000 Hz
- T.H.D: 0.2% at f = 1 kHz
- Max. SPL: 120 dB
- Microphone output: unbalanced
Dimensions
- Length mic boom: approx. 150 mm
- Capsule diameter: 13 mm
Other
- Ring and tip: AF, shaft: ground
USB converter Connections
- PC/MAC: 1 x USB Type A (M); cable length 1.5 m
- Audio: 2 x stereo jack sockets (3.5 mm)
- Operating system: Windows®, MAC
- Operating temperature: 0 °C - +60 °C
- Storage temperature: -20 °C - +60 °C
- Dimensions L x W x H: 76 x 30 x 16 mm
- Weight with cable: 45 g
Only £259.99 inc VAT.
PRE-ORDER NOW
QH-1339 Features
- 5-year warranty
- Art.Nr. 3300
Headphone
- T.H.D: < 0.2%
Microphone
- Max. SPL: 120 dB
Dimensions
Other
PRE-ORDER NOW
