- 28 Dec 2009
- Wales
Anyone had any new results?
^ thats a very nice clock.
I cant really get above 975 on the core even with 1225 volts, and memory seems to be around 150ish max.
Mainly game at 974/1076 at 1200volts - should be able to lower this a bit, but im happy with temps atmo
Right just had a bash and stable at 1000 core 1150 mem on 1218 volts.
Gaming for an hour on that the temp hit 66c so I hope thats not too high??
Quick question, enabled the 1000/1250 overclock using the catalyst control centre and is this alright? Will it change voltages automatically as it does not have voltage control tab?
I assume this is all ATI will safely let me do, possibly on stock voltages and the afterburner allows more volts to go beyond these limits?
That's well low - anything below 85C is fine.
How did you do that? Mine only allows 850/1250 overclock in Catalyst overdrive tab? I had to use Sapphire's Trixx or Afterburner to go higher.
And no, Catalyst overdrive won't touch the voltage setting (but you probably know this by now!)![]()
