like the idea aypez, think it's time that i explained why i didn't plan for an entrance/exit which you could walk through though;
creepers actively hide in places that the player is likely to go, it h happened a lot with the old workshop that was just outside spawn (later turned in to the mine), frequently people would walk out to be greeted by a creeper hiding to the side of the door which is a pain as every time you leave you need to rebuild the wall!
the reason i had the idea of using the trains as the only access is that they are secure (if you make them that way) and they lead to all sorts of interesting and available space, which helps keep building round spawn to a lower level.
i do agree that there needs to be some way, is there any way we could do like a moat or something and then have dock (just outside the doors) which we could launch boats from?
Fabien I've been working on the subway tunnel to our bit from spawn, using up my tnt
Here's what's been done so far. Fancy finishing it?
Uploaded with ImageShack.us
also just a simple double door with a wall of glass for the outer door means you can easily see if there's a creeper there. and if necessary you could go above and shoot it with arrows.(use stone for the the inner door though)
right, since somebody keeps ****ing around with the gardens and undoing my work, i cant be bothered with it any more.
What gardens j?
Sorry about not being able to finish the Auction House earlier, I'll try and get on later tonight to work on it a bit more but don't wait on my account! Just go with what you feel works![]()
I've got quite a lot to do with the bank interior anyway.
