Caporegime
- 11 Mar 2005
- Leafy Cheshire
I'm not sure i've not messed around with logging for ages but i always thought it was better than that, will check it out tonight need to use Vag-com myself anyways.
not really, stage 2 doesn't do much to bottom end at all, but allows more top end due to the front mount dramatically reducing heat soak and the exhaust system (mainly the larger downpipe) allowing better gas flow
You get the adjustable ones but they are weaker than solid metal ones for obvious reasons, also a waste of money if you're capable of cutting and welding up your own ones to necessary length
I can't comment on the front whiteline ARB, I can't see it making much difference in terms of handling at the front personally, although the rear whiteline ARB is an EXCELLENT handling mod for VAG hatchbacks
I don't see why there's uproar at a claimed 6.5s to 60, that's pretty normal for a remapped 150ps mk4 gti with nothing but a re-map
lol@having to rag a FWD for that 0-60 time
How are you "tweaking" the ECU?
What have you done to achieve those supposed 200bhp+?
with a laptop and software and a cable via the obd2
