you need to recall her straight away thats a priority.
next you need to put what you want on here and il order it for you, you can owe me
I want the M3 that Tom posted please
I work away which means i work all the time, allll the time not 9 to 5 5days a week.
I can see why you've called yourself MrLOL.Ok questionning aside, do you really have any idea of what sort of running costs a car like the RS4 has ?
What do you project you'll need per year ?
OP: Get that M3
My friend had a BMW M3 and it was nice but I have always been put off them for some reason.
The RS4 in my eyes is the one or at least at the moment, like i said im going to test drive when i can.
And 30k is a lot for a car BUT... If i work hard then when i rest ill want to drive a nice car. No point working my balls out to keep it in the bank ay.
RS4 for me at the moment, any other takers.
thanks for replys too.
Engine
As befits a car with an engine built to near-racing standards, an RS4 is happiest when used regularly and vigorously. Otherwise the valving in the crankcase ventilation system tends to let oil accumulate in the inlet tract, which leads to blue smoke on start-up and a build-up of carbon around the inlet valves. Some oil consumption is normal.
The RS4 can suffer occasional coil-pack failure, so beware of misfires. The engine management warning light should alert the driver to this but doesn’t always do so, and the unburnt fuel from the resultant misfire soon destroys the catalysts, of which there are two.
The actuators for the exhaust bypass valves can seize up so check you get the right rush of sound in Sport mode.
i suggested that, i dont even want commission
Noted, shekels ok?
Wow really? That sucks![]()
£30k for 3000 miles is crazy. So it's basically an ornament for your driveway.
As that is the case I'll offer a different car - F355.
Given the mileage running costs should be limited (as they can be at least!).
