- 25 Nov 2002
- Somerset
On the off chance, I just tried installing Windows XP Pro 32bit and its installed.
The only change to the bios was to set SATA to IDE mode to avoid install driver issues.
Just installing the Intel Diagnostics and will run that.
Then I will try installing each of the Asus / Intel drivers one at a time to see what and if makes if fail.
SB does overclock higher and cooler but also very fragile. Hope this is just a one off, QC slip, otherwise, these forum will be be inundated with similar issue.
it's saved me many times and spotted bad cpus. I always test all faulty intel pcs with it before I even carry on trying to troubleshoot. Happy it helped you track the problem now.
