Coolermaster HAF X Case Owners
15 Jul 2007
South West
Hi
Whats this case like please:
1: Good or bad airflow?
2: Quiet or loud case fans?
3: Quiet or loud for HDDS?
4: Plenty of room in the case?
Be most grateful if someone who maybe owns or owned the case can help me please,ive read reviews but id rather hear peoples own opinions
Many Thanks
Hi
Many Thanks
1. The airflow is awesome and the case is kept very cool because there's a huge fan on the left side panel in addition to top and back fans.
2. The whole case is pretty quiet after you've shut the side panels. The thing that might sound the most is the PSU.
3. You will hear you HDD unfortunately, yes. Ge an SSD, man! No moving parts, no annoying sounds :)
4. Oh yeah, you could fit you cat there^^ No, seriosuly if you want a case where you can put all the cables at the back then this is it. It makes your computer very clean and easy to maintain. If you don't have a modular PSU all those extra cables can be hid away at the bottom of the case. I also love the ease of installing a hard drive, you won't need any screw and they are placed 90 degrees to the right so you can see where you need to stick those cables:)
