Am I right in saying the Sandy Bridge chips also come with graphics? If so when you add a discreet graphics card for games what use could you put the sandy bridge graphics to or would it just become redundant?
Same as an onboard GPU on a mobo really, slot a card in and you can't still use the onboard can ya
Also, Asus R3, before one of the mods shouts at you, your sig is twice the size it should be - 4 lines max mate![]()
Whats with all these questions all popping up from people with hardly any posts? Almost all of them can be googled or just searched on the forum or even actually just stop a second to look at the cpu forum section where there are 10's of sandy bridge threads. Failing that could have just posted in one of these threads if it was too hard to comprehend how to figure things out for your self.
Getting kinda annoyed with these now.
to comply with rules......
what are the graphics like on SB like.
thinking about getting a SB setup and then getting a new card later on.
do both 2600 and 2600k have graphics in the chip
is that comparing a SB with a hd5570
would like to no what the on board graphics are like.
would it compare to an i7 920 and a gtx480?
i dont know much about these chips. (only just started reading up on them)
ok Albert! ill read it now make you happy. forgot its you forum.
maybe you should make a new forum were only you can ask questions to things you dont no about. then google them. then answer them.
