Im sure his motherboard is the x38 chipset, ive tried googling to find some info on theses cards with a q6600 but cant find any
Let us know how you get on, if they perform ok then you could always try clocking your q6600 a bit higher
Did you try crossfire with the original bios before you flashed them
no one runs Heaven with 8xAA and Anisotropy 16x![]()
that things messed up as hell. it has to be a bottleneck.
OH lol thats probably the problem.
seany84 you could try overclocking the q6600 with less ram because i was just rememerd that when i first had my q6600 i was on xp and 2gb ram and i could run at 3.6ghz but as soon as i installed vista 64 and added another 4gb of ram i could only get 3ghz oc, im no expert on overclocking but im sure you can get a higher overclock with only 2 sticks of ram and if your useing 4 x 2gig sticks this will still leave you 4gig in the system which will be enough for you to test with
