How much of a mess is that professional tap going to make? Aren't they usually used in gigantic bath sized sinks? Been thinking of getting one myself.
no integrated washer and dryer
Also, those pro taps are nice to look at but become a real ball ache when you have to use them all the time in a normal kitchen environment
Is that a TV wallmount I spy there? if so, is that not WAY too high?
Otherwise really nice kitchen, good size
I like the window made out of newspaper... did you run out of cash for glass in that one?![]()
rG-tom said:looking back at the last page, it's a real shame you didn't go for a range, the first time I do any kitchen renovation I'm definitely getting a range! Had one in a rented property and they're so nice to cook with compared to even normal gas nevermind induction Otherwise really nice kitchen, good size
no integrated washer and dryer![]()
Make-shift blinds, until the curtains go up.
I can't stand cleaning range cookers. We have one where we are now and it gets on my wick when we cook something simple like bacon and you spend 20 minutes cleaning the grease from the nookes and crannies.
@AmTechFox.. we do have a spare room![]()
Yes, what I great decision. They're crap.
Firstly you cannot wash and dry at the same time. We do this a lot as it speeds things up.
Secondly integrated units tend to be poorer at drying than a dedicated dryer, as the drum size tends to be smaller than you'd commonly find in a dweicated unit.
If you have the space, always go separate.
I think he means integrated into the units mate, as to hide them![]()
In that case I agree
.Yes, what I great decision. They're crap.
Pics.
Professional tap in, just need a blanking cap for the front of the sink.
Excuse the mess. All the crap is in the kitchen so the rooms that need to be carpeted are free.
Hmm wont you have an issue opening those doors on the corner cupboard there. Unless that is a 900 L Shaped corner unit the handles will knock into eachother and you wont be able to open the doors fully...
Looks very nice however!
My only thoughts/critisism's are re the appliances and fittings in that i do agree that higher end integrated appliances may have looked smarter, as would a porcelain kitchen sink rather than a stainless.
Money saved there is better spent in the rest of the build.
