Mine auto overclocks to 103 * 39 or 4ghz and it dishes out 1.240v vcore in the process... I guess some can auto overclock to 4.3 and others only to 4.0ghz
Its better to do it manually and set BCLK too 100MHz and then use the multiplier to overclock.
Is there anyway to make the cpu run at 3.3ghz all the time instead of 1.5ghz when it has nothing to do?
Yes disable speedstep in the BIOS. It's not really a good idea though, speedstep is very good, you get the power only when you need it.
Does the same work for the ram? does it only use it when it needs it?
Gibbo, quick question,
For the purpose of this question, lets say the max vcore is 1.3v
When setting the vcore in bios, say for example to 1.28v, and when booting to OS shows 1.28v in CPUZ, and then, when underload, due to the bios compensating for the vdroop, the voltage rises to 1.32v, is this considered to be over the normal working vcore (1.3v), or should the max vcore, when under load be the max vcore?
I'd say maximum safe voltage is 1.38-1.42v. Its gonna take a few days to test as were trying to kill a CPU. First step is to see if 1.65v memory volts kills it, if after 48hrs prime its still alive I think we can rule that out.
Next step will be to shove 1.45v through it and clock it to around 5GHz and just leave it going and see if it dies. If it lives, then we can point our finger elsewhere or when its a combination of both high vcore and high vdimm.
Maybe we should open a competition about what finally kills it?
Answers in the following format
5700mhz, 1.68v cpu vcore, 2.8v ram volts, 115 bclk
HI there
Right memory at 1.65v seems absolutely fine, still not a single issue with our rig, still going strong in prime.
I think the issue is coming from anyone trying a combination of the following:-
1. High Vcore
2. High frequency memory
3. High Vdimm
I think when your trying to push its just too much for the CPU to deal with voltage wise.
These chips to get the best results shoud ideally be set at:-
1. 1.35-1.40v Vcore for maximum overclock and ideally 1.30v for 24/7 running.
2. Keep memory frequency ideally around 1600MHz and tighten the timings up.
3. Keep memory voltage sub 1.55v
4. Keep chipset/pll at default and BCLK at 100MHz.
I think the above setting will yield 4.6GHz-4.8Ghz happily but with complete stability and a system that run around the 75c mark.
I will clock to 4.6ghz then leave it at that, what should I change these memory timmings to???
Corsair Dominator, 1.65v 2 x 4Gb
CMP8GX3M2A1600C9
CL9 ( 9-9-9-24 )
XMS3 DOMINATOR® with DHX+
Thanks for any advice.
These are just guidelines we recommend you follow, if you want to push more voltage through your CPU's then just be aware they could die on you. Your warranty is un-affected and we will honor any CPU's that die, we just won't ask questions as to how you killed them.![]()
