Ok so update time from me...
I've been running into problems getting much above 3GHz
I'm fairly sure its a memory problem but as far as I can see there is no way of changing the Command Rate to T2 its forcing it to be T1 on my motherboard with no option to change it in the Bios! I'm on the latest Bios and it seems I'm not the only one with the issue after a quick google search! It runs fine as T2 at stock speeds and on a 667MHz Dev but at 533MHz it decides it can do T1 at those speeds and gives me no control over it!!!
Not good!
Anyway so:
Just look at those Volts
Seems stable but yes need to run it longer to be sure, its completed 3D Mark 11 fine at this speed also.
Now for the problem:
As you can see its T1 and if I increase the bus speed upto 270MHz I get BSOD's as soon as I get passed the windows logon screen... sometimes get to the desktop and then BSOD. I've tried lower HT & NB, more volts on CPU and even a little more on ram, setting ram to 400MHz dev which resulting in me having to reset the CMOS altogether...
I when searching on google I found someone say that setting them in single channel allowed them to run T2 but I tried this as you can see in the screen shot without success...
I can't really see a way around this without changing the motherboard or getting some higher speed memory... unless Asus fix it in a Bios upgrade... really annoying.
I do as it happens have a cheap and basic MSI 770-C45 so might give that a go as it would do all I need feature wise but loose the option of crossfire... but it would mean a reinstall / reactivation of windows 7 which would be a real pain... I guess I could install windows on another hard drive etc but all a pain and takes up a fair bit of time etc...
To Confirm... Full Specs are:
Asus M4A785TD-V Evo
Ram: 2x Corsair CM3X2G1600C9DHX (2GB Sticks)
CPU Cooler: Tuniq tower 120
Case: Antec 1200
GPU: HIS HD5770
I think that's all that's required
Any ideas?
