- 15 Feb 2003
- Europe
I typed HD2 in google and got something else. doh
set up a google reader account online, add the feed, then dl newsrob from the market, its superb.I have an RSS feed that I want to receive notifications from on my phone when a new post is added - anyone know what is the best way to achieve this?
Man I can't tell you how useful Colonoscopy Prep Assistant is!
MY COLONOSCOPY WENT SUPER-SMOOTH, NO HITCHES. THE CAMERA PRETTY MUCH SLID RIGHT IN AND HAD A REAL FUN TIME IN THERE. THANK YOU SO MUCH.
Check in the settings if you haven't already. Stockholm is the default location, and it can be set to automatically revert to that if it can't detect your location.
any good apps to replace the stock calander? It's not pretty at all.
I'd also like one that marks off all the UK bank holidays and important dates
m.tvcatchup.com has BBC news.
Sorry ...
Unfortunately, your country is not currently supported.
At this time, TVCatchup is available only in the United Kingdom.
Media player
Currently use Coreplayer for music and videos, so would ideally like an all in one solution. If it can smoothly play 800x480 videos (encoded from 720p) it would be a huge plus.
Alarm
Currently use G-Alarm. Like having multiple alarms, volume settings, fade settings, and being able to select my own. Gentle Alarm seems to be highly rated, yes?
One of the most annoying issues in Android land is that there are plenty of times where your keyboard will be hiding something you need to see. It may hide where you are typing, or the next text field you want to get at, or there may just be a bug and your keyboard won’t go away. there is a better way to show/hide your keyboard and it is a universal trick.
No matter where you are in Android, even if there is no reason at all to bring up the keyboard, all you have to do is long-press the menu button on your phone to toggle showing/hiding your keyboard
You can subscribe to UK holidays in Google Calendar if you browse interesting calendars. Then they will just sync as per any other. The only other calendar I've been relatively happy with is Pure Calendar.any good apps to replace the stock calander? It's not pretty at all.
Thanks, got that on there nowset up a google reader account online, add the feed, then dl newsrob from the market, its superb.
Radiant HD is good, but I was sad that you can't upgrade all your weapons before it finishes.
Can anyone spec me a good app for running/jogging?
It would be good to have GPS route tracker for the run to log the distance, time and the speed, possibly upload to a website to view all the stats etc and log history?
