Man of Honour
- 20 Dec 2004
- Tamworth
I bought a second hand Q6600 and Abit IP35 Pro motherboard as an upgrade for second PC. I have noticed that Windows Task Manager only shows 2 graphs, device manager only shows 2 CPU's, CPU Z only shows 2 cores and Real Temp only shows 2 cores. But all of these correctly identify the CPU as a Core 2 Quad Q6600.
The POST screen in the BIOS detects it as 2 CPU's. There isn't an option in the BIOS to enable or disable any of the cores.
I have removed the CPU from the board and refitted it.
All clock speeds are default.
The BIOS is flashed to the latest.
I have re installed Windows 7
MSCOFIG advanced boot options only lists 2 CPU's
Rescanning for hardware changes in device manager shows only 2 CPU's
Diabling the CPU in device manager, restarting PC and redetecting hardware only find 2 CPU's.
I have tried disabling/enabling the following in the BIOS: C1E Function, Limit CPUID MaxVal and Virtualization Technology.
Does anyone else have any other suggestions to try? My Google powers have failed to come up with anything else.
Thanks in advance.
Thanks in advance.
