Final Check
29 Dec 2010
Hey guys, I'm soon going to be ordering the parts for my new PC, and I've spent absolutely ages making sure every part is good enough for what I want. I just want to double check again before I buy, as I'm new to PCs and I want to make completely sure I'm doing it right, as I probably won't be upgrading much for a couple or so years. I've already got the graphics card and PSU, as i saw they had a good deal going on for them at Christmas (GTX 460 768mb and CM GX550W. )Currently what I've got is:
Intel Core i5-2400 3.10GHz (Sandybridge) Socket LGA1155 Processor - Retail £145.99
MSI P67A-C45 Intel P67 (Socket 1155) DDR3 Motherboard £101.99
Antec 100 One Hundred Ultimate Gaming Case - Black £44.99
G.Skill RipJawX 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel £41.99
Seagate Barracuda 7200.12 500GB SATA-II 16MB Cache - OEM £27.98
LG GH22NS50 22x DVD±RW SATA ReWriter (Black) - OEM £16.99
Sub Total : £316.61
Shipping : £10.00
VAT : £65.32
Total : £391.93
The question is, what do you think of my rig for around a 550 pound price point? Is it worth it, and will it be good for gaming, running games at full with 1920 by 1080 resolution and some AA/AF? Also, if I were to upgrade to an 15 2500K, are there ways which I can cut down on my budget, and also should I change the board to something crossifre or sli enabled? Or is one slot enough, as I can just buy a whole new gpu to replace my gtx 460 when it becomes outdated?
Sorry about the number of questions and the text, but thanks for any help I get :)
Thanks, but what do you think about the motherboard and the dual gpu options? And would the 2500k be a reasonably practical upgrade seeing as I have absolutely no experience of overclocking. Is it hard? Hahaa cheers
Can't cut it down unfortunately. Perhaps Phenom II X4 would be the way to go?
RE SLi I would just upgrade the GTX460 when you feel it start to slow down - P67 chipset SLI boards are few and far between, and very costly!
Overclocking a K series chip is super easy - you change change the multiplier, and increase the volts slightly when the PC crashes/hangs/bluescreens :p
Okay that's not a problem, but is 2500k worth the 50 pound more at this point, when I've never overclocked before? Also, is it advisable to go for a phenom X4, as from all the benchmarks I've seen the 2400 outperforms it quite substantially?
Keep what your thinking of getting, have added a few alternatives above, but its small change.
Hmm I see what you mean, and I kinda like the look of the RipjawX ram, shiny and red :) I guess thats what I'll get then, last question; is it hard to overclock the non K series CPUs? Is the procedure different? Thanks for all your help!
Yeah, i's so its worth £50 more
KK thanks man, but is hard to OC the i5 2400?
Hard? Its impossible.
Intels way of conning enthusiasts into paying through their teeth.
You can only overclock none K series chips with the FSB - and every 1155 board can only increase FSB by 2-3.
EDIT: Just saw you have a Antec 100 has your case - you could save £20 by changing it to a Xigamatek Asgard - still a decent case.
Oh right...damn I may have to consider getting the i5 2500k then, thats another 50 quid out of savings account :( Although on some website reviews, they have somehow managed to OC a i5 2400 to something like 3.7 to 3.9 ghz, I don't see how that's possible from what you guys are telling me tho? Also Cookeh, I quite like the look of the antec 100 and plan on installing red LED xigmatek fans on the front, because I'm like that haha :) How good is the Asgard?
Obviously there are reasons its cheaper - but it'll house your stuff, keep them cool. Cable management will be a bit trickier, and there are less fan mounts. But, saves you some monies :p
Ah fair enough, I do like to have more monies :) But then again, I do prefer the look of the Antec 100, and in the future when I want to upgrade my graphics card it seems to have enough room to fit a 5970, so I should be set :)
If you do upgrade later, you won't be upgrading to a card that's already last gen :p
