whats the difference?
22 Mar 2009
Cornwall
hi, apart from £10, what would be the difference between :
Specifications
Gigabyte 5770 1GB DDR5 DX11 XFIRE 2DVI/HDMI/DPORT
Chipset: ATI Radeon HD 5770
Core Clock: 850 MHz
Mem Clock: 4800 MHz
Memory: 1GB
Memory Bus: 128 bit
Memory Type: GDDR5
Card dimension: ATX
Bus Type: PCI-E 2.0
Bus Speed: x16
Maximum Digital Resolution: 2560x1600
Maximum VGA Resolution: 2048x1536
D-SUB: Yes
TV-OUT: No
DVI Port: Yes
VIVO: No
Multi View: Yes
and
Gigabyte 5770 1GB DDR5 DX11 SUPER OC HDMI/DPORT
Specifications
Series: Radeon HD 5000 series
Chipset: Radeon HD 5770
Key Features: SOC
Core Clock: 900 MHz
Memory Clock: 4800 MHz
Memory Type: GDDR5
DirectX: 11
D-sub: Yes
DVI: Yes
would i notice a great deal?
I wouldn't have thought an extra 50MHz on the clock would make a huge difference. It's your call if 3 or 4 extra FPS is worth a tenner or not :). If you can run to a little extra, a 768 MB GTX460 would blow both of them away.
Specifications
and
I highly doubt you'd notice a fps difference of 50 hz in a card like the 5770, especially if you don't play games like Crysis. However they can both overclock, and I'm pretty sure that they'll both OC to the same level. However I'm not sure that they've been 'binned' differntley, if they are, the more expensive one would be more stable.
Basically, if you're planning on OCing, get the cheaper one.
And even if you arn't, I highly doubt you would notice the difference, but it is only £10.
You can find them for £118 if you look around. How much are the 5770's now?
Edit: ah, just seen your second post. 6850 is by far the best of those :)
That's a great price. Out of the list HD6850 is by far the best option.
the HD6850 would be around the £110 mark, which if its worth the extra then might be better off aiming for that. dont wanna go too mental as i dont really use it a lot, but want to know that if/when i do, im not gunna be hit by lag and poor gameplay.
and being ATI i wont need a cable to the mobo for HDMI audio (or do newer Nvidia ones not need it either)? also, will the cpu/mobo (AMD ATHLON II X2 250 AM3, GA-M52LT-D3) cause a bottleneck on that card?
At 1080p you would definitely see better framerates with the 6850. Rest of the system won't bottleneck it for most things. The 128 bit memory bus on the 5770 is a bit of a problem at high resolutions.
6850 slightly below 5850 although better at DX11 (crackers naming system). Equivalent to 768 MB GTX460.
so would a 1024MB GTX460 be better? do the newer Nvidia cards still suffer from the audio over HDMI issue where you need a cable to connect the card to the mobo?
No idea about the HDMI issue. My card didn't come with any extra cables so I expect it's been fixed. 1GB is noticably better, but more expensive again. The price for the 6850 sounds excellent by the way.
The HD6850 1GB is actually slightly faster than a GTX460 1GB:
http://www.techpowerup.com/reviews/HIS/Radeon_HD_6850/28.html
It also only requires a single PCI-power connector meaning it also consumes less power too.
An HD6850 1GB overclocked by 165MHZ to 175MHZ for the GPU consumes less power than a GTX460 1GB at stock clockspeeds when under load:
http://www.anandtech.com/show/4002/amd-radeon-hd-6850-overclocking-roundup-asus-xfx-msi/8
