Your Gaming Surface?
22 Aug 2010
Recently the OcUK Selection of gaming surfaces has been growing. We have re-introduced Qpad back into the selection due to their specialised hybratek coating. I use the Qpad HeatoN pad, not had any problems. Just wondering which pad you use and if you think it has improved you're gaming experience.
Here are a few of our newer / best pads:
Qpad heatoN Gaming Mouse pad @ £29.99 inc VAT
The pad itself has a dimension of incredible 43.5x36.5x0.35cm (17.12x14.37inch) which makes it almost impossible to slide off the edge. Previously you have only found such large pads made out of traditional cloth, but are now also available for all hard top fans out there. The surface is constructed in a 3 layer construction. Starting with a high quality cross weave rubber to make it stable on the table. The second layer is an abs plastic sheet to give it stability and weight. The third layer is made from an extremely durable carbytek plastic that offers a very good glide in combination with unique micro precision. The combination of a spongy 2mm rubber base with an abs board in between and the hard top surface gives it a new feeling never felt before. The weight of almost a half kilogram makes it very stable and firm on the table.
- Size 43.5 x 36.5 cm
- Thickness 4 mm
- Surface Carbytek technology. Hard top plastic
- Colour black
Only £29.99 inc VAT.
PRE-ORDER NOW
Qpad Grin CT Large Mouse Pad @ £23.99 inc VAT
For all users with high demands on precision, feel and functionality this is the mouse pad that delivers. CT™ series smooth Hybratek™ coating ensures that the mouse registers every detail of the smallest mouse movement. It offers a smooth and a controlled glide with an optimum level of friction. Whether you are a hardcore gamer or work with other demanding tasks such as graphic design or large spreadsheets, you’ll thrill to the task.
- Size: Large: 40.5x28.5cm
- Thickness: 4 mm
- Grin design
- Surface: Hybratek Coated soft top
Only £23.99 inc VAT.
PRE-ORDER NOW
Razer Goliathus Omega Fragged Control Gaming Mouse Pad @ £13.99 inc VAT
Lab-engineered by Razer's scientists and field-validated by the biggest names in professional gaming today, the Razer Goliathus Control Edition greatly enhances the precision and tactile response of gaming-grade mice without introducing excessive, fatigue-inducing drag and premature surface degradation. The tournament-tuned textured weave enables mice—regardless of sensor type—to register the minutest of movements, thus yielding unprecedented targeting and tracking accuracy while maintaining a perfectly controllable yet consistent glide.
- Heavily Textured Weave For Maximum Mouse Control
- Pixel-Precise Targeting And Tracking
- Optimized For All Mouse Sensitivity Settings And Sensor Types
- Dimensions: 270mm x 215mm x 4mm
- Rubber Base For A Secure Grip On Smooth Surfaces
- 2 Year Warranty
Only £13.99 inc VAT.
ORDER NOW
Qpad CT Large Mouse Pad - Black @ £20.99 inc VAT
- Thickness: 4 mm
- Color: Black
Only £20.99 inc VAT.
ORDER NOW
Qpad UC Medium Cloth Gaming Surface @ £11.99 inc VAT
If you're looking for a mousepad that gives you total control while letting you enjoy working the mouse, choose QPAD's new uncoated surface mouse pad the latest in a wide portfolio of proven QPAD products. Our new, four-millimeter thick pad features a soft yet resistant surface designed to let you feel the mouse's movement over the pad's uncoated surface for better control. Portable and robust, you can roll it up, stick it your pocket and slap it down for the next game. A cross-weave rubber underside firmly grips the table where you place it. With its signature winged shape designed for an extra-wide sweet spot, UC is a superior quality soft pad that lets you do the work and gives you a sense of mastery.
- Size: 35x25.5cm
- Thickness: 3mm
- Color: Black
- Surface: Uncoated cloth surface
Only £11.99 inc VAT.
ORDER NOW
and of course the ultimately famous
Boogie Bug AimB.Pad XL Gaming Mouse Surface @ £16.99 inc VAT
The AimB.Pad has been especially designed for gamers looking for precision, fluidity and the perfect harmony between slide and friction. This XL version also represents an essential tool for graphics designers, architects and other users looking for precision and wide movements. Its surface has been made with flexible textile material that not only assures fluidity and precision in the movements, but also allows the AimB.Pad to be folded, rolled up and transported.
- Dimensions: 450mm x 900mm
ORDER NOW
The Boogie Bug is becoming quite the celebrity at OcUK!
If you do own a Boogie Bug XL mouse mat, post your pictures!!
Corepad Cloth XXL. I love it - you never run out of mouse mat, as I can't physically reach beyond it :D
OcUK doesn't stock it though - you should.
No razer exact mat :(
Razer Exact is EOL but the nearest replacement is this :
Razer Vespula Dual Sided Gaming Surface @ £33.70 inc VAT
The dual-sided Razer Vespula™ Gaming Mouse Mat provides two distinct gaming-grade surfaces on an abrasion-resistant hard coat to suit your preferred level of gaming glide —SPEED for smoother fast-paced action that maximizes freedom of movement; and CONTROL for ultra-precise movements and tactile feedback with its textured surface, allowing you to adjust your mousing surface to any specific gameplay-requirements with incredible ease. Extended gaming sessions are now possible with its memory conformance wrist rest that is designed to reduce fatigue for additional performance enhancing advantage over the competition. Take the fight to your enemies’ doorsteps with the Razer Vespula.
- Non-slip, anti-reflective, abrasion-resistant hard coat
- SPEED surface for faster mouse movements
- CONTROL surface for precise mouse movements
- Size: 300mm (length) x 240mm (width) x 4 mm (height)
- Comes with a gel-filled wrist rest"
Only £33.70 inc VAT.
ORDER NOW
I use an exactat too and like it a lot.
Got a Puretrak Talent on its way from the US soon and this is supposed to be an awesome pad will let you know my thoughts on it. If it's as good as i've read then you should consider stocking it if possible.
GZA
Your Gaming Pad
Fixed for correct spelling :p
I use a SteelSeries QcK pad - it's crap, slips all over the place! What would be the best replacement? (Game at around 1000dpi if that makes a difference, and movement is wrist/arm based)
Maybe the Goliathus? (Choose your size). The reason I didn't get a Goliathus is that they have Control or Speed versions and there was some differing opinions on what this actually meant.
Logically you would think the speed version is a very smooth surface for you to move your mouse quickly with less control but some said it's the other way around to suit your style i.e. Low sensitivity users should go for the speed and high sensitivty users should go for the control.....confused the hell outta me so I went for the Puretrak Talent.
I use the Steelseries SX, but frankly i need a bigger mat these days.
I play more low sense than i used to...
Anyone recommend a good largish mat for use with a G500? :)
[WU-TANG]GZA;18255893 said:
Suffices? :eek:
So you play with mouse and kb for HL2 but for CSS and TF2 you use a x360 pad and find it better? :eek::eek::eek::eek::eek:
noooooo, can only play with mouse and keyboard on most Valve based games, prolly why i'm cack, lol
looool, mouse and keyboard suffices for HL2 and such but i get trashed on CS:S TF2 lol
That's odd. Two members of my Div4 team in TF2 use 360 controllers, and I know a few CS:S pros who use them as well.
I've never been able to grasp them (on consoles anyway :p).
GZA, where did you find the source for confusing/contradictory info on the Goliathus? I have been looking at it, but I'm unsure of which I would need :p
Or is there an alternative mousemat I should be looking at?
There is a new Goliathus coming out, bigger version I will be stocking :)
Anyone recommend a good largish mat for use with a G55? :)
Depends on how large. If you looking huge then boogie bug is the right choice for size and price. If your looking for slightly smaller the HeatoN based on the famous CS player is very good and big enough for people who use lower DPI.
Razer destructor on top of Qpad masterpad on a black felt desk cover. Makes for nice padded softness for wrists etc, with stupidly precise tracking on my mouse. Going from an old fail pad > qpad masterpad > steelseries something > Razer destructor and having tried out friend Exactmats, icepads and some other random "high end gamer pads" at LANS:
I can state that it is by FAR the best mat I have ever used, I even believe the marketing speak on the front as it is so much nicer to use for AutoCAD and gaming, whether I am playing FPS or RTS etc. Tend to use it on 5700 DPI but in AutoCAD I often will be down at 400-800 and its still awesome.
