Fine if you need them quieter for higher clocks, but I don't like those coolers which pulls the heat from the GPU straight into the case. Talking from experience, you want most of the hot air vented straight out of the case and this relies on your case having excellent cooling. The cooler looks quite tall as well which could be worry for SLI setups in the dissipation of heat which could be disrupted.
