^^ Are those fans on CPU red but washed out by the CCFL or are they orange?
If they're red, what ones are they and how do they perform?
They're 256 colour xclio fans
[/IMG]![]()
. I have Cooler Master HAF 922 which has same interior as Cooler Master Storm Sniper. I also have 2 red cold cathodes like the ones you have. I had trouble placing 2nd cathode as my other one is at the bottom in the same position as your's. I had the 2nd one vertically placed over the optical/hard disk bay area lol but now my 2nd one is in exactly the same position as yours; vertically placed next to mobo and it looks very sophisticated
. The material is usually shiny.KiiYzOo you r the man!!. I have Cooler Master HAF 922 which has same interior as Cooler Master Storm Sniper. I also have 2 red cold cathodes like the ones you have. I had trouble placing 2nd cathode as my other one is at the bottom in the same position as your's. I had the 2nd one vertically placed over the optical/hard disk bay area lol but now my 2nd one is in exactly the same position as yours; vertically placed next to mobo and it looks very sophisticated
Now guys does anyone know what red material I can use to cover my cold cathodes as they glow bright orange after a while. I have seen people placing some red material on the cathodes and they produce pure red light but can't remember the name. The material is usually shiny.
Thanks
Try getting some clear red material
. There is also mention of RED led strips:Btw what cpu cooler fans are those attached to megahalems?
 I got them from a different site though.Set them to blue so they match the other lights.
I have them set to go through all of the colours![]()
They're 256 colour xClio led fansI got them from a different site though.
.Woah!! just checked these fans on youtube and the colour shifting is awesome. Almost like a water fountain surounded by different glitzy light.
 Good for the HAF X and it's large size + high airflow.
Umm the only tips I have, is to keep it simple eg. 1 HDD etc, modular power supply and a good cable management case, I basically built my components around my case to get it right, it took a while but I'm happy with it Even though it's already out dated lol. ThanksTbh, that is incredible for the neatness of the front... I serioulsy wish mine looked like that... do you have any tips?? Mine in my Storm Scout starts to struggle with the back side being put on with all the cables on the back :S
! Sir you have good taste haha
.another cm 690 ii with freezer 13.
The living room entertainment system
