- 7 Jul 2003
- Westergate
Windle too much to lose with vaults etc
I can update the server to latest revision and still maintain a whitelist, you'd lose tp etc until Bukkit arrives though!
What's the vote?
my client appears to be doing something new, and rather annoying.
"Play online once to enable offline play."
and the usual "can't connect to minecraft.net"
cant play at all now![]()
Server 2 updated to 1.2.01 for those who want to play the latest version of Beta![]()
Have sent you an email just to confirm your mp email so I can add you to the server users list.
I've not been able to login to servers since the last update.
I'll give up until the next update for now I think...
I was just about to downgrade to check if the main server is working, and my minecraft updates. so I do what I usualy do and use the old minecraft zip to overwrite everything other than the version file, and for some reason it still auto updates when I try to login? I'm not sure why this is happening as the minecraft version file should show it to be the latest version regardless of what version the files actully are.
