Ah, don't go to a ton of appointments, you'll end up doing a ton of credit searches :/
Really? I didn't think they did a credit check until one of the later steps?Ah, don't go to a ton of appointments, you'll end up doing a ton of credit searches :/
Yep, 4 or 5 year deal fixed. House price about 200k, maybe push up to 215k. Deposit of 65k-70k. Joint income of 33.3k.Find the deal you want and speak to that bank. I'd only go to a broker if that didn't work out.
You want a 5 year deal, right? What's the purchase price you're thinking of and the deposit?
. Bit annoying really as she wouldn't give us a rough figure without running it all through the system. Both of us are on the electoral role, and have never had any late payments. I've had a credit card for about a year and paid that off every month.Don't check your credit score, it's a waste of time. You can check your credit record for problems... but I wouildn't worry about that for a mortgage.
You should make sure you're on the electoral register but it takes a while to come into effect so it may be futile.
Don't check your credit score, it's a waste of time. You can check your credit record for problems... but I wouildn't worry about that for a mortgage..
I don't understand that comment....was it meant seriously?
I did yeah. The credit score that Experian sell you is worthless. Looking at your credit history isn't worthless, but I wouldn't go to the trouble of doing it unless you feel there's a problem. For a mortgage the credit history isn't anywhere near as important as for unsecured lending.
