Hey guys, I'm having real issues with my PC of late, I've tried a lot of things, but its time to go to the experts!
Basically, my 4800 would display jargon, all distorted imagery unless i booted in safe mode with it disabled, I would still get white lines across the screen so I bought a 5850 while it was on offer from OCuk.
I installed it with no issue using the relevant anti static band etc and it seemed to work fine, the PC itself however was starting to get slow after a few hours usage so I figured a fresh format and install was needed. I woke in the morning to do this and found that my PC would not display anything at all, just a black screen with no keyboard or mouse light.
After reading around, i did something called a cold restart? where you hold the power button down with no cable attached, anyway this worked and it booted again to considerably worse performance than before and my computer displayed 4 gig ram (2gig usable).
Ever since this its been unstable and very very slow, sometimes requiring another cold restart to get loaded so I did the format a few hours ago. I reset the bios to factory settings, formatted the C: and new partitioned it. Installed a fresh copy of win 7 64 bit os and installed all the latest drivers, tweaked all my bios settings to run stable with no overclocking.
Now windows runs nicely, I've had no problems with slow down but when I check my computer, it still says it sees 4 gig with 2 gig usable and when I enter a game, its so slow, the performance is way worse than my 4800?!
Is this a duff gfx card with a fault do you think? or it is something simpler such as the wrong configurations on the RAM/GFX?
I really appreciate any help and support you could give me, Thanks again!
