gtx560 or 6950?
I am older than you and have a worse computer for gaming!
Think how much you will need to spend after selling your old card. Is it worth the extra cost of the upgrade??
A GTX460 768MB is still a decent card at 1680X1050.
At the end of the year there will be better £200 cards for sale IMHO.
I do think it's worth the upgrade, and I did have to sell a few things just to be able to buy the parts for my PC.
Leave him alone, he's 15, has peer pressure from his "mates" to have cool things and has to learn on his own. ;)
Yeah something like that :p
Yeah that was one of the reasons towards the 6950.
Even though I'd love to go 3d, I just don't think its worth saving up for that long or selling loads of things to get it as i'm only 15 and earn £20 a week :(
Lol, at 15, I was gaming on a Playstation 1 let alone a decent gaming PC rig!:eek:
It's only January. We would never upgrade on that philosophy, would we?;)
you make a good point there ;)
by the end of the year, even if the cards are way better, if I see any huge framerate drops in up-coming games, I'll just buy another 6950.
To be honest the point about the end of the year this time around make sense as there is a sizeable drop in size (from 40nm to 28nm) which means that roughly if you keep the chip the same size (physically) you will be able to fit many more transistors in there. So it is not going to be an efficiency change like we've had now but a much more important change. I will wait unless your is struggling.
To get the most out of 6950 (unlocked to 6970) crossfire, you need to upgrade your CPU from your current i3 to a i5 750/i5 760 overclock to 4.0GHz, and it would cut it very close, if not over your PSU's rating in terms of power consumption:
http://www.legitreviews.com/article/1488/18/
One thing really puts me off about the new cards such as 6970 (or unlocked 6950) and GTX570 is that they are quite high power consuming. To be honest, if I'm was on only 1680 res like you and already got a GTX460 768MB, I'd just overclock it and wait till end of the year and upgrade to a 28nm card than one of these power hungry beast.
Get the XFX 2GB HD 6950 and then flash it to a 6970
All their cards flash to a 6970 easily with no reported failures apparently.
Jobs a good 'un :)
seems it would depend on the games u play. BFBC2 for example loves teh 560
and is quite an improvement over a 460 at 1680x1050.
I would upgrade my psu before then anyway.
Yeah but the 6950 flashed to a 6970 is even more of an improvement :)
Not really, as 6950 flashed to 6970 is not going to be faster than a proper 6970. And if you look specifically at the BFBC2 results above, you could tell the GTX560 will run ahead of even the 6970, when overclocking comes into play.
Also, the GTX560 is much more cooler running and consume less power than the 6970, or 6950 flashed to 6970.
One thing you should note is if you overclock your GTX460 768MB to around 800MHz+, it will pretty much match the speed of the GTX470 shown in the benchmark result above, and at no extra cost!
The flashed 6950 oc's too, which will still be faster in most games, and give him better average dos due to double the memory. Even if he gets a 1g core oc because most 560's are not going past that. In this case as op is 15, I imagine he has no issues on how much power the cards consume and just wants the best performance he can get.
The overclocked 560 is faster than stock GTX570, which itself is faster than the 6970 2GB at 1920 res 4xAA. Yes 6970 (or 6950 flashed) overclocked from 880MHz to 950MHz would would probably be marginally faster than the GTX560 at 1000MHz, but at what cost? Average £30 more on the card, plus higher power consumption and heat and noise.
Anyway, in terms of bang for bucks, NOTHING comes close to the GTX480 at below £195 :eek:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-222-AS&groupid=701&catid=1914&subcat=1750
