- 2 Dec 2006
Hello, well my laptop has been blue screening like crazy and slowing down terribly in games and I've stress tested it and everything and it seems its not a hardware problem but is in fact a software problem. Thus I am trying to format my laptop. However when I boot from the w7 disk and try to format my hard drive nothing happens. It acts like its going to start formatting and then just continues as if I never asked it to do anything. I've now got w7 installing again as I wondered if maybe the formatting was part of the installation but I'm thinking its not so I want to format it after its finished reinstalling. I figured it was best not to quit the installation once it had started.
Any ideas? I'm wondering if it is infact the disk I am using. Unfortunately I only own the w7 upgrade disk from dell, which is of no use to me so I had to borrow a friends disk to format it and its a pirated one. I'm wondering if for some reason the pirated ones can't format? Tis a long shot. I am not pirating windows as I do own a key, it's just I only have the upgrade disk not the retail one as dell are cheap and want me to install vista and upgrade to windows 7 in order to install it again.
Maybe I could use my vista disk to format and then put the w7 disk in? Failing that am I to presume it is infact a hard drive problem?
