Muscle Vests
you don't need any decoration! ;) :p
Your rug is your decoration!
I think you should shave a croissant and other french baked goods (baguette) into your body hair. Though this might just end up looking like you've shaved the outline of a johnson into your bodyhair! :p Show us how much of a patriot you really are! :D
I'm a fan of a hoodie rather than a vest/tshirt. Might just be to stop the cold bar touching my neck when squatting though:D (ye I know, hyper gay)
That reminds me, really winds me up when I see people wearing hoodies with their hoods UP.......... Do these people not realise how ridiuclous they look? :confused:
No no, I mean when they're casually bustin' out some mean curls whilst thrusting their entire torso forwards and backwards to really isolate those biceps...........
I train in white (ribbed) calvin klein ones i picked up cheap in macy's over seas. dont know how much they run around here though? Pretty good... pretty thin which is the reason i train in them.. i sweat like a beaver in a sauna. try TK Max in your local town in the underwear section for tanktops?
Hood up is acceptable for heavy squats as it makes you look badass. Anything else it's a no go for.
I see quite a few people train with hoods up and headphones on. Not really fussed personally but I usually take me huddy off for squating more often than put the hood up.
my gym has no heating i must be the only one here that trains in two tshirts, hoody pair of jeans and boots lol.
I use baggy Everlast t-shirts - the lightweight ones with the breathable panels down the back and under the arms, and a bandana to keep the sweat from running down my face.
